DCPower and DAQmx Communication
Hello fellow LabVIEW developers,
I am trying to synchronize a PXIe-4139 and a PXIe-4464 and after studying the 'LabVIEW Help' I am unsure how to do it.
Maybe one of you can help me.
What I intend to do so far:
The PXIe-4139 is going to be my source for DC current where I want to generate a sequence of current values.
The PXIe-4464 is my voltage measure unit.
For each sequence iteration there will be an event created and send to a PXIe-4464 trigger.
Upon receiving the trigger the 4464 measures the voltage corresponding with the sequence iteration and creates an event which is routed to the 4139 which then continues with the next sequence iteration...so on.
Is that the correct procedure or is there a faster way for achieving my goal of synchroniced action of the two units?
Regards
Message 1 of 1
(2,510 Views)
