DC Motor PID Tune Simulation
I'm interested to control a DC motor model but with another input which is TL.... for example in Labview there is simEx DC Motor.vi which has two inputs Voltage and TL if I set TL to Zero and concerned only with Voltage ...I can tune PID using the manual (trial and error) method (stated in this tutorial https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4ToCAI&l=en-US ) but when I increase TL to some value, I can not tune PI controller...any help or suggestion please?
A.Hakim
(5,409 Views)
We might need some more information on what you are using and trying to do. I can't find the example you mentioned, what version of LabVIEW are you using?
Is the TL input you mentioned referring to Tyreus-Luyben rules for PID or something else? A screenshot of your code or some more details would be very helpful.
Thanks!
Zach P
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
(5,386 Views)
I want to control the speed of the DC motor (In hardware) using IMC (Internal Model Control) tuned PID in labview. I have to interface the hardware with software using DAQ Card or using Arduino UNO R3.
At present I have to simulate the dc motor speed control in labview. Please suggest me how should I do the simulation.
Herewith attached the block diagram of my project.
Thanks & Regards,
Neelam Punjabi
(5,273 Views)
Hello Neelam,
Thre is a very well documented white paper online you can refer to for  DC motor control using LabVIEW.
http://www.ni.com/white-paper/12944/en/
Best of luck with your project.
Regards
Luis S
Application Engineer
(5,252 Views)
Hello Luis,
Thank you so much for the reference dear. I tried to simulate the same in Labview but I am getting this error" Error -2369 occurred at Transfer Function in PID+DC (NW).vi/Control & Simulation Loop"
Please suggest me how to remove this error.
Thanks & Regards,
Neelam Punjabi
(5,217 Views)
