DB Tools Create Table
Hi.. i got this error while trying to create a database
Conn Execute.vi->DB Tools Create Table.vi->CreateDatabase.vi<ERR>Exception occured in Microsoft Office Access Database Engine: Syntax error in CREATE TABLE statement. in Conn Execute.vi->DB Tools Create Table.vi->CreateDatabase.vi
(3,649 Views)
Accepted by topic author sharinganez
I cannot open your vi, however in many cases the syntax error is caused by invalid table or field names (invalid characters, embedded blanks or reserved words). In this case, you may want to change names; alternatively, you may enclose them in square brackets: [my_column_name].
If you open the DB Create Table.vi -> Conn Execute.vi block diagram you can capture the full text for the SQL query and post it so we can take a look at it.
Paolo
(3,634 Views)
1. What is the database you use?
2. Please fill in all controls on frontpanel, and right click on them>>Data Operations>>Make Current Value Default. Then, save, and attach it again.
3. Also re-attach screenshot that could show full error code together with UDL file, and database file (if possible).
(3,607 Views)
Hi pincpanter
Yea you are right!
its Table name problem
After i change it, its ok now.
Thanks pal!
(3,601 Views)
