DB Insert Example question
    I want to insert data into a SQL database using the Insert Example.vi, as a base for my code.  I have to add a large number of parameters to the database.  My questions:
Is there a limit to the number of parammeters I can add?
I noticed that the example added two parameters (Device name and number of samples)  It then uses "DB tools free object.vi" two times.  Do I have to call the "DB tools....vi" once for every parameter I send?
thanks
Bob
(3,249 Views)
Hi Fluitron,
Could you please let me know what toolkit or module you installed that contains the insert example vi? Also, what version of LabVIEW are you using? Please let me know. Thanks!
Steven
(3,222 Views)
There is no "limit" to the amount of fields that you can pass through an ODBC to SQL other than your connection timing out if it is EXTREMELYYYYY large.... I would guess that for all practical purposes you would not reach this point.
You can use the Insert Data vi which you would just have to specify the table name that you want to insert. Keep in mid that if you use this functiuon, you need to insert a cluster with THE SAME exact amount of fields as your table in the database. You would use this function if you want to insert a value to every single field in the database. If you dont, then you would use the Execute SQL Query vi, which you would wire a string with your query which in this case would be an INSERT statement.
I hope this helps.
Jaime
(3,219 Views)
