DAqmx in timed loop
I seem to be experiencing some strange behaviour with a DAQmx application I am putting together. Basically, I set up a continuous DAQmx task across 2 PXI-6133 cards to acquire all 16 channels at 200kHz. I also setup a digital task to acquire digital samples from one of the cards. All 3 tasks are synchronised to the same clock source and trigger event to start the acquisition. So far so good.... Next I unload a fixed number of samples (100k which is .5 seconds) inside a while loop. If there is no delay inside the while loop then the Read multiple DAQmx function uses all my CPU resources. As a workaround, I use a wait for ms with around 450ms which produces a stable output, no errors. If however I replace the while loop with a timed loop, I immediately get DAQ error -200279. Even reducing the period on the timed loop to 10 ms does not seem to be enough to stop the error. Any ideas are appreciated, I also tried putting the whole thing inside a timed loop and using a case structure so that the initialise section only happened on first call but this did not work either. Attached is the VI.
Dan
(3,612 Views)
try adding shift registers to your while loop for all of the DAQmx tasks.
Kenny
(3,591 Views)
Thanks kenny, I tried that as well as changing to a timed loop and using shift registers on the timed loop. There is also another problem in that even when using the while loop with delay method, adding a timed loop anywhere else on the block diagram (even if it is doing nothing) causes the daqmx task to fail. I'll log it as a tech problem and see how I go.
Dan
(3,563 Views)
