DAQmxBase DSSetHandleSize
I use MAC OS X (10.4 tiger) and installed now LabView 7.1. I additionaly installed lvtigertools. In LabView 7.1 I have now daqmxbase examples, i.e. Cont Acq&Graph Voltage-Int Clk.vi et al.
These vi examples are compiled without any errors. But when I start the vi I always get the error message:
Couldn't find LabVIEW bundle; function=DSSetHandleSize".
Something must be wrong now in my LabView? Was lvtigertools the bad thing?
Who has a similar problem?
Who can give me a hint to solve the problem?
Rudolf Lehn
(3,690 Views)
Hello Mr.Lehn,
I have read also your another massage and I know you are using USB-6008.
Which version of Mac OS X 10.4 is installed?
Which versions of DAQmx Base are you linking?
I would recommend you to install the DAQmx 1.5 B driver from this page:
http://digital.ni.com/softlib.nsf/websearch/31593803B856C5AC86256FF8005FA4EB?opendocument&node=132060_US
Please let me know if the reinstallation from driver did not help.
Best regards
AmirG
(3,675 Views)
Thank your very much for your hint.
I use OS X 10.4.3
I download now DAQmx_base1.5.0f2.dmg, but I think I used this already. I think it't worth to test.
Rudolf Lehn
(3,672 Views)
Hello AmirG,
I see an interesting problem. I don't get my error message "Couldn't find LabView bundle; function = DSSetHandleSize" with my PowerBook G4 (the same system OS X 10.4.3 and the same DAQmxBase), but the error exists on my G5 Desktop.
But what could be the reason?????
Rudolf
(3,664 Views)
Hello Mr.Lehn,
I’m also really interested to find reason for this behaviour.
I have one question more:
Did you install of both computers the same LabVIEW version?
Best regards
Amir Gracic
(3,642 Views)
Hello Amir,
I use on my PowerBook G4 exact the same LabVIEW 7.1.1
I really think my problem was a result of different USB ports on my G5. But I will investigate.
Rudolf Lehn
(3,637 Views)
