DAQmx task data logging
Can someone pls kindly help me attached vi?
I have difficulty in datalogging part. I need to read 4 Channels Thermocouple k type sensor from NI9211
Need format of Datalogging in Date , Time and 4 Channels of Thermocouple (each column each channel). Every one min write to .tdms or .xls or .txt file. and Collect data log for 1 day in a file. Front pannel displaying Temp value read every 1 min.
Have some restriction to do my project due to I have to run the project in executable file and can not be used with DAQ assistant..
Can pls kindly help me with datalogging for every 24 Hrs log in a file.. Either in .tdms or .xls or .txt format..
Thank you very much,
Brian
(3,325 Views)
The requirement to not use DAQ Assistance is admirable!  Read this White Paper and you should get off on the right foot.
(3,310 Views)
Also look in the LabVIEW Example Finder.  There are a few good examples in there for data acquisition without the DAQ Assistant.  You might be interested in the Thermocouple - Continuous Input.vi.  You should also become familiar with the TDMS and File IO functions.
(3,303 Views)
