DAQmx reset.vi and NI-9205
in a compact daq   CDAQ 9178, the following modules are inserted in the following order
NI 9205 (DSUB), NI 9264, NI 9482, NI 9482, NI 9482
I usually try to identify the boards by using daq max commands as attached in the vi
The issue here is :
If the DAQmx reset.vi is used, the 9205 module is not indentified
Is there is a reason for that?
I have been using this setup for a long time with Daq boards, and never had the issue.
(1,503 Views)
It is because you have an error as highlighted at the bottom.
Note: DAQmx Reset.vi is a non-blocking call (means, it does not wait for the reset process to complete but just initiates a reset and returns), it takes a few minutes for the DAQmx device to complete reset and boot properly, if you query before the device boots up, you will get an error.
Santhosh
Soliton Technologies
(1,502 Views)
the issue here it never happens with boards (like PCI/e cards, that I used in the past) also with the other modules in the sane CDAQ.  Why specific to the 9205 ?
(1,490 Views)
A number of potential reasons.
1) A PCI(e) card is located in the PC, Sending commands to it is usually equivalent to writing one or a few values into some register. With the hardware inside the PC, this is literally a move over the internal data bus that takes the CPI a fraction of a microsecond to do. For a cDAQ everything has to go through the network. DAQmx has to build a data package, send it to the device, the device decodes it, executes it and then sends back another package over the network to acknowledge the command with a pass or fail status and any other information it may have. This involves at least one bidirectional network transfer, sometimes more and that can easily take up many milliseconds for each single command.
2) Those C modules all have some internal hardware that needs to be (re)initialized. A Reset means basically forget everything I ever told you to configure your channels and go back to a defined default state. This can involve autocalibration routines that will be performed and that will generally require some time to execute as the settling times of the signals need to be fully observed. For calibration purposes you do not want to use almost correct values due to not fully observed settling times, but the values need to be as accurate as possible. Slower acquisition usually gives more accurate measurements, so a calibration routine can take up some serious time to perform. Some modules will therefore need some time after a Reset before they are in a state that they can answer other requests.
LabVIEW has to say this about the error you show in your example:
Error -88705 occurred at ..........
Possible reason(s):
The specified device is not present or is not active in the system. The device may not be installed on this system, may have been unplugged, or may not be installed correctly.
This would pretty much match with point 2) above and together with the additional network delay things simply get even more visible.
Rolf Kalbermatter  My Blog
(1,461 Views)
It has nothing to do with the way you call reset, but an inherent behaviour of each DAQmx card, if you call reset and some other operation fast back to back you will definitely see the same issue in other cards as well.
The way I learnt this is on a PXI system involving 4463 and 4464, these were on a top-of-the-line system with PXIe controller, so I would say this is nothing specific to 9205, just give each card its own time to complete the reset process and don't rush it.
Santhosh
(1,435 Views)
The 9205 actually does do quite a bit during reset.  One thing that actually takes quite some time is the internal temperature compensation.   Of course,  that means the device must forget everything it knew about its internal temperature and take some temperature readings to find what it's current stable temperature is after waiting for any self-heating effects of the internal sensor.   This takes time.  It will not respond to other commands while it is performing this vital process.
"Should be" isn't "Is" -Jay
(1,429 Views)
