DAQmx read write sub vi empty channel
I am new to Labview
I have created a sub vi to read and write from DAQmx.
I have attached sub vi with this post.
when I add sub vi to one of my projects and select physical channel I/O I was not able to see any ports and lines.It's blank.
Can anyone please analyse my read and write sub vi and let me know what mistake I have done as I was not able to select any ports.
(3,935 Views)
Hi VikashKumar23,
You will need to have a physical channel in your system in order to link a physical channel to your LabVIEW program. You can either use physical NI hardware, or simulate it in NI-MAX. If you do not have a NI module on hand, you will probably want to simulate one.
Cheers,
Duncan W.
(3,918 Views)
Accepted by topic author VikashKumar23
Your name filtering is wrong!  Right click the Controls and open the filter options dialog
"Should be" isn't "Is" -Jay
(3,907 Views)
Actually, I have a physical NI DAQmx hardware which is USB-6509
I am interfacing it with SCB-100 breakout box.
I have done several other projects with this hardware but without using a sub vi.
now i would like to use sub vi. Unfortunately I could not able to see any channels.
I have attached additional file where you can see the channels i have used and it's working fine.
(3,904 Views)
