DAQmx not showing terminals
double clicking donot open a window.... thats the problem....
Message 11 of 13
(742 Views)
Accepted by topic author Assad-Ur-Rehman
Hi Assad,
as RavensFan said before: you need to install a DAQmx version which supports the LabVIEW version you want to use.
In your case anything from DAQmx9.7.5 to 16.1!
When you were asked to provide an image of the software tree in MAX it doesn't make sense to (partially) cut off the important numbers behind the software items…
Message 12 of 13
(735 Views)
Thanks That worked
Message 13 of 13
(730 Views)
