DAQmx installer not found
Hi there,
I am trying to build an installer for a simple DAQmx application (I tried to make it as simple as possible for my first installer, just to prove I can make one), but when a click 'OK' to finish the build specification, I get an error stating that Labview can't find my DAQmx installer. I attached a screenshot of the error.
I am using Labview Home and Student edition 2014 currently, and have been keeping it up to date when the VI Package manager when it prompts for updates. I had also tried to build a similar installer using the full version of LV 2014 at work, but also had issues finding the DAQmx installer. What gives? Is this an add-on I need?
thanks!
-Jeff T
(2,914 Views)
(2,856 Views)
Jeff.  You need the installer for DAQmx to build the installer for you application.  you do have DAQmx installed but do not have a local copy of the installer.  you need to insert the media to copy the installer for DAQmx to your harddrive
"Should be" isn't "Is" -Jay
(2,853 Views)
Thank you, I had not seen this yet. Looks promising I'll have to make our IT people dig up the CD.
(2,842 Views)
Thank you I will need to try this. I wonder if this is possible for the Home & Student edition also, for which there was no CD - I purchased a download to the installer.
(2,841 Views)
