DAQmx generate zero
Is there some way to send a zero or a dead signal in my first case structure, so I can lock the signals in my array? (first case structure = index 0, second = index 1 and so on).
(2,217 Views)
I don't understand your question.  None of those case structures generate anything.  All they do is create a channel for the task.  Data is only generated latger on when you start your task.
Isn't this pretty much what you are also asking about in your other thread?   https://forums.ni.com/t5/LabVIEW/Choose-of-multiple-sensors-from-same-module-DAQ/m-p/3946907
Please keep the conversation in that thread since you are already receiving help there.
Note you can always create a channel and read data from it, but if you want to ignore that data, replace the waveform you receive with 0's or NaN's at that point.  Rethink what you are trying to do and how you are doing it.  You'll get a better result with less work.
(2,171 Views)
