DAQmx error
Hallo,
sometimes I get the attached error when running one simple .exe that reads from one USB9211A and close one contact on one USB6501.
I installed DAQmx 8.1 which should be the latest driver release for Labview 7 express. I tried to uninstall and reinstall driver but nothing changes.
SO: Win2000, Labview 7.0 express.
Could someone help?
BR,
Pier
(3,054 Views)
Hi Pier,
the screenshot you posted does not give much information about the cause of the problem.
It could be a problem of broken files in a corrupted installation (see this post ) or most probably a problem of bad programming, given the fact that the error seems to happen just sometimes randomly (see this post).
Please check that your code correctly complies to DAQmx programming guide. If you want to be sure that DAQmx are correctly installed, try to check the cards through test panels of MAX.
Have a nice day,
Giorgio
(3,031 Views)
