DAQmx data acquisition
Hi, guys!
I am a freshman.
I have a trouble with DAQmx channel configuration.  I have two channel  to configure ,one  need  IEPE ,and another one  not , but in  the  example ,I have  to configure  both  of them to be IEPE stage or not .
And the  help  context tell me I have to use the  DAQmx  API to specify  the desired configuration .The question  is I don't  know  how to do it .
If you have any suggestion  or example, I would  be appreciate.
You can find the example with the guide  of the following picture .
Thx !
lease Mark the solution as accepted if your problem is solved and help author by clicking on Star kudoes.
(4,105 Views)
@mittly wrote:
Hi, guys!
I am a freshman.
Welcome to the Forums.  I'm glad that at least some Freshmen are learning LabVIEW (at my University, they "allow" me to give a single LabVIEW talk to the BME Seniors, usually in their final semester as they are rushing to finish their Capstone project.  Too little, too late ...).
Because you are new, you probably haven't heard my "Attach code, not pictures" rant.  If you attach an actual VI, if there's a Broken Arrow, we can find the problematic function, and we can "investigate" more thoroughly.  One drawback is if you have lots of VIs and attach just one, there will be "missing" functions, but that can often be overcome by compressing the folder containing your Project and attaching the entire .zip file.
Another (minor) point, but might as well start off on the right track -- some very accomplished LabVIEW Gurus might frown on being called a "guy".
OK, a Very Good Point in your favor -- you did not use the DAQ Assistant, but rather tried to dive right into DAQmx.  Good for you!  Go to the Web and search for "Learn 10 Functions in NI-DAQmx", read the excellent NI White Paper, and use some of those techniques.  In particular, take your device, open it using MAX (NI's Measurement and Automation eXplorer), and see if you can configure the channels as you want.  If so, you can save this configuration as a Task in MAX, and, even better (in my opinion), you can create a Task in the LabVIEW Project associated with your code.  [If you don't know about LabVIEW Project, look it up and start using it!].
(4,044 Views)
Thanks ,I will keep your advice in mind.
(4,011 Views)
Mittly,
     I recommend that you edit (or remove) your Signature.  It is missing the initial "P", and you also don't seem to be aware of what it says (I'm assuming my advice was useful ...).
(3,993 Views)
