DAQmx buffer property node not available
The following question was posted to the 'Multifunction DAQ' forum.
Since I received no respones, I'm trying it here:
I transferred an intact VI from a desktop PC to a laptop.
On the laptop, however, the VI does not compile since the property node "DAQmx Buffer" is not available. I suspect that I maybe did not install the full DAQmx suite on the laptop but I don't know which part might be missing.
(On both machines there is no DAQ hardware installed since I was just trying to do some editing.)
Is my suspicion correct? and how do I find out what's missing'?
If my suspicion is not correct: what else could it be?
TIA
Franz
(2,944 Views)
If  I can guess you should check which versions of daqmx are installed on both machines!
Ton
My LabVIEW Ideas
(2,932 Views)
Dear Franz
Obviously, LV versions prior to 8.0 didn't have the "DAQmx Buffer" property node. Do you happen to have 7.1 or older on your Laptop? Then you should update.
Best regards
Philipp Roessler
(2,915 Views)
