DAQmx Task
Another question for ya.
I have a DAQmx Task called "QuickCapture" on one computer that I need on another. How do I find this to recreate or transfer it? If you need more information let me know.
Thanks.
Message 1 of 8
(4,051 Views)
Hi Neil,
open MAX on your development computer and look for any DAQmx tasks in there…
(It's a bad habit to define DAQmxTasks (and other stuff) just in MAX, when you plan to port your program to a different computer…)
Message 2 of 8
(4,044 Views)
Under the File menu of MAX, you have the option to export the hardware configuration to a file. Do this, copy the file to the new pc and use the Import function.
Message 3 of 8
(4,034 Views)
Thanks for the tip. This is someone else's code that I'm trying to edit.
So there are no tasks on the computer that I want "QuickCapture" on.
Message 4 of 8
(4,031 Views)
Why would you expect any tasks on the new computer?
I'm not sure I understand Gerd's comment about a bad habit. Creating a task in MAX is pretty common. Including the tasks with an exe and using an installer is also common.
Message 5 of 8
(4,011 Views)
Hi Dennis,
it's a "bad" habit because people tend to forget to include those tasks with their exe/installer - as you see in this thread 😄
Message 6 of 8
(4,007 Views)
Well, I think the bad habit is people not RTFM but I see your point.
Message 7 of 8
(4,003 Views)
I didn't expect anything to be there. I was just trying to get on the same page with Gerd.
Message 8 of 8
(3,997 Views)
