DAQmx Task Recovery
Due to failed hard drive I need to migrate un-exported DAQmx tasks from one computer to another. Due to the same issue with hard drive I cannot open DAQmx and export these tasks - windows based system is down.
Does anyone know where DAQmx keeps its tasks? What files does it use to store the tasks by default?
I can recreate them on the new computer. I just need to know what they are, what cards and IOs they use.
(3,549 Views)
Accepted by topic author arhangel123
Hello arhangel123.
I believe the information you're looking for can be found in this KnowledgeBase article:
KnowledgeBase 4GA9TOQA: What is the Process For Resetting the MAX Database?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC&l=en-US
The latter part of the document is written to step you through manually deleting the database - don't actually.follow the procedure outlined there, but it does identify the relevant files/folders which I think is what you're looking for.
Best Regards,
Tom L.
(3,536 Views)
Thank you. That worked exactly as it should.
(3,519 Views)
