DAQmx System property errors only in executable
Hi Everyone,
I am experiencing a problem with the DAQmx System properties [LabView 2017 (x64); Windows 7 Enterprise SP1].
The property node works just fine when I run the VI, however when I run the executable built on that very same VI it gives an error [-2147220689 for DevNames; -229771 for Tasks]  crushing the application.
In the sreenshot attached: on the top side the VI, on the bottom side the executable, on the right side the back-end.
Has anyone a clue? Am I missing some configuration properties in the app builder?
Thank you
(2,858 Views)
Accepted by topic author Mitch85
(2,814 Views)
after resetting the MAX database, I re-built the application and now it works. I had no idea a corrupted database could affect the application built on a fine working VI.
Thanks a lot!
(2,802 Views)
