DAQmx Stop Task missing
I am trying to run a project and when i try to open the .vi file, the message that the DAQmx stop task is missing. i have installed the drivers multiple times but i'm still getting the same issue. Is there a way to uninstall the drivers and reinstall or something? Where are the files usually located when the drivers are installed properly? I don't know what to do. Any help would be greatly appreciated.
I know that there are posts about this issue and that the fix is to install the drivers. However i've tried to install all versions and it keeps saying that a higher version is already installed. I'm worried that maybe i installed to high of a version and it's not compatable with 2011. Could that be the issue? How do i correct this if so?
Thanks for your help!
(3,467 Views)
What version of DAQmx did you install.  According to this, the latest version of DAQmx that will work with LabVIEW 2011 is 14.5.1.  You need to uninstall DAQmx and then install a compatible version.
(3,453 Views)
