(DAQmx) Reading Circular Disc Profile Using Eddy Current Probe.
Hello Every one,
I want to setup a DAQmx voltage task to read Circular Disc profile using eddy current probe.
Disc is rotating at 200 RPM scanning every row. (Plz Refer attached image )
eddy current probe is shifting to next row after completing one rotation (360 Degree) till last row .(Total number of rows are 32) For Every row circumference is reducing.
I reading data for complete single row when i get trigger for one rotation is complete using DAQmx Read function.
But at the end after collecting all Rows data i m getting array size different for each row
i have kept
Continues Sample with Multiple Channels
Sample Clock Rate = 10000 and Samples = 5000
and For Read Function No Samples = (-1) kept floating (Which is in while loop) i m taking data out from Read pallet when i get one rotation is complete trigger (Used Case Structure)
I m plotting this Data to Intensity Graph but due to change in array size for every cycle defect position also gets changed . i m plotting it to the 0 -360 Degree range
I would like to know what Design pattern should i used and Sampling Rate and No. of Samples .
(3,718 Views)
Hi AtulS,
use an encoder to provide a certain number of pulses per rotation.
Use those pulses to externally trigger your ADC sample clock.
Then you get the same number of samples per rotation!
(And even better: then those samples will be distributed equally with respect to rotation angle - and not in time like you do right now!)
(3,700 Views)
Time taken to complete one rotation for Disc is 240 ms is constant for all rows i m
reading data from Read function after every 240 ms for 32 rows.
Externally Trigger ADC Clock means i have to create another task to read no. of encoder pulses and apply those triggers to Sample clock function.
plz correct me if i m wrong i don't have much knowledge  about this.
 is there any other way bcz i don't have Encoder to test it out.
(3,684 Views)
Hi AtulS,
To "externally trigger ADC clock" means you need DAQ hardware supporting external sample clocks.
You don't need any additional task. All you need then is to tell the current DAQmx task to use the external sample clock: there is a "source" input at DAQmxTiming function…
plz  …  bcz
Please read this! 🙂
(3,677 Views)
@GerdW wrote:
Hi AtulS,
plz  …  bcz
Please read this! 🙂
Thanks for your Reply.
I am using NI-6220 Card to read Eddy current Probe voltage  and Trigger for one complete rotation.
Is there any other possible solution Except Encoder.
(3,669 Views)
Accepted by topic author AtulS
Hi AtulS,
It supports also external AI sample clocks (as well as other kind of triggers).
So you could use this trigger as a start trigger for the AI task: when a new revolution starts the AI task is starting to take samples. You could maybe also use it as stop trigger to stop the AI task after the revolution is complete…
An encoder would be the most accurate option as it would allow angle-based measurements independent from rotation speed deviations! Check your requirements before deciding which hardware to use…
(3,658 Views)
Thanks For Reply.
Start and stop position is same for one revolution how do i integrate this logic for multiple rows.
is it possible to you post some VI snippet so i can refer.
(3,636 Views)
