DAQmx - Read AI digital values
Hi!
Simple question: Is it possible to read directly the discrete values from an analog input channel?
The result of a "normal" DAQ AI aquisition are DBL samples. In fact that the card converts the input voltage with an ADC into a digital value its waste of memory to use DBL for lets say a 12bit conversion. I use the following hardware, but this should be possible for every card:
- NI PCI-6110
- NI PCI-6711
Best regrads,
Michael
(3,328 Views)
Accepted by topic author MK_MTEngineer
Ok found it in the VI "DAQmx Read (Analog 2D U16 NChan NSamp).vi". Seems to be that nobody uses this... i never saw a LabVIEW example with such a simple way to read out the REAL AI data.
Michael
(3,317 Views)
