DAQmx Read 1D Boolean
I have a DAQmx task that I programatically populate with multiple digital input channels. I want to read all channels simultaneously, using the DAQmx Read 1D Boolean.vi
My question is, does the order of the output array match the order that I added channels to the task? Or does it match the physical channel order on my hardware?
(2,852 Views)
Accepted by topic author sirwin
The order is defined by the task.
This should be easy to test. If you have two inputs that you know (or have forced) to be different, you can set up one task with (use your actual channels) "ch0, ch1" and "ch1, ch0" and make sure you read back the results reversed from each other.
(2,823 Views)
