DAQmx Library problem with upgrade from 7.1 to 8.5
I used to run a labview 7.1 program (myprogram.vi) with DAQ7.3. Last month I lost my install disc of Labview 7.1 so I upgraded the labview to 8.5 and installed Labview 8.5 into another computer.Also, I installed DAQ7.3 onto the new computer as well. Then I copied the 7.1 program(myprogram.vi) to run it in the new computer. Now comes the problem: Whenever I open the myprogram.vi, Labview prompts that these .vi files are missing and asks me to designate where they are. --It is surpring because most of the missing file begins with DAQmx, although the DAQ7.3 was also installed. I tried to find these vi files, but I could neither find them in the computer with labview7.1 nor the new computer with labview 8.5. Where should these library vi files been to?
DAQmx Control Task.vi
DAQmx Stop Task.vi
DAQmx Start Task.vi
DAQmx Timing(Implicit).vi
DAQmx Timing.vi
DAQmx Create Channel(CO-Pulse Generation-Time).vi
DAQmx Create Virtual Channel.vi
DAQmx Create Task.vi
DAQmx Read(Analog 2D DBL NChan NSamp).vi
DAQmx Read.vi
DAQmx Clear Task.vi
DAQmx Create Channel(Al-Voltage-Basic).vi
DAQmx Create Channel(AO-Voltage-Basic).vi
DAQmx Write(Analog Wfm 1Chan NSamp).vi
DAQmx Write.vi
DAQmx Start Trigger(Digital Edge).vi
DAQmx Trigger.vi
DAQmx Timing (Sample Clock).vi
DAQmx Read(Analog 1D Wfm NChan NSamp).vi
Al Read(scaled array).vi
Al Read.vi
Al Clear.vi
Al Start.vi
AO Write(waveform).vi
AO Write.vi
AO Trigger and Gate Config.vi
AO Clear.vi
AO Start.vi
AO Config.vi
Al Config.vi
DAQmx Timing(Use Waveform).vi
DAQmx Write(Analog 1D DBL 1Chan NSamp).vi
DAQmx Wait Until Done.vi
    Anybody can help?  Thanks
(3,028 Views)
I think you need to use DAQmx 8.6 with LabVIEW 8.5.
Message Edited by Matt W on 08-31-2007 08:00 PM
(3,027 Views)
