DAQmx Digital Output Values
Hey, how do I take six boolean values and put them into a DAQ Assistant box that's set up to output data.  The DAQ assistant says it wants an array, but when I merge the signals, they form DDT.
Can I take six wires and "merge" them into an array?
(3,122 Views)
I found "build array", but it's not quite what I need.  I need to control individual lines in a single DigitalOut port, I believe.  How would I set "P0.1" to zero?
(3,115 Views)
Hello bmunden,
when you set up DI/O in DAQ assistant express VI, youc an choose either 'write to lines' or 'write to port'. In the first case, you will need to add as many channels on the port as you have Boolean inputs (six in your case). Then the input will accept your boolean array, as in the upper block of code in the attached screenshot. If you are just addressing the port, it is expecting a number (like '5) which is then converted to boolean output (0101). A work-around to convert the array to number is shown in the lower block of code, but I really think you want to go with the top example, but with six booleans.
-Mello
Data Science Automation
CTA, CLA, CLED
SHAZAM!
(3,105 Views)
Ah, but of course.  "Write to line" is one of those pieces of instructions that I normally overlook when I'm in a hurry to get the thing working.  I've been using Windows too long.
(3,100 Views)
