DAQmx Control Task.vi missing
I'm using Labview 2011 Student Edition for OS X.
I want to open a project created with Labview 2011 on Windows.
When loading libraries, it asks me to locate the file "DAQmx Control Task.vi". I have installed the appropriate drivers (for NI USB-6009, found here: http://joule.ni.com/nidu/cds/view/p/id/2892 ). However, the required library was not installed with this package.
What can I do?
Edit: if I choose to ignore the missing file, it also wants:
DAQmx Fill In Error Info.vi
Convert DDT to 1DDbl.vi
(4,978 Views)
The list of missing files, continued:
XY Chart Buffer.vi
DAQmx Create channel (TEDS-AI-Voltage-Basic).vi
Convert 1DDbl to DDT 2.vi
(4,969 Views)
Hi Shears,
NI-DAQmx Base, the DAQmx software for Mac OS, does not contain all of the files that the windows DAQmx software contains. This is mainly due to DLL files which are used on Windows OS not being compatible with Mac.
Thank you,
Eden S
National Instruments UK & Ireland
(4,964 Views)
So there is no way to run this project on OS X? Ok then, thanks.
(4,962 Views)
Hi Shears,
No, it will have to be run on a Windows OS.
Thank you,
Eden S
(4,960 Views)
