DAQmx Channel Analog Input TimingMode
Screen Shot 2023-06-01 at 10.55.50 AM.pngScreen Shot 2023-06-01 at 10.55.50 AM.png
Following a tutorial for a multi-channel data program, but the timing mode channel function can not be found where the tutorial is showing. Is anyone else running in to this issue? What else can I try?
See attachment.
(3,200 Views)
Hi lschefter,
If I Browse the DAQmx Channel node properties then do a search for "Timing", I get two Digitizer/ADC properties: "Timing Mode" and "Custom Timing Mode" but neither of them can be selected.  What is it you're trying to achieve? I've been using DAQmx for 10 years or so and have never come across these.
Andy
(3,185 Views)
Thank you for the quick response!
I was following this tutorial:
https://youtu.be/fIy6XT3CdPQ
At 3:30, the speaker decides to add this DAQmx Channel because he observes his instrument is collecting & plotting data at a very slow rate?
(3,175 Views)
Accepted by topic author lschefter@rollins.edu
Right click the property node,
Choose "Select Filter"
Select "Show All Attributes"
Your device may not support that property.
(3,161 Views)
Thank You! This worked!
(3,125 Views)
