 _Bryan
			_Bryan
			04-28-2009 09:48 AM
 Will_S.
			Will_S.
			04-29-2009 06:15 PM
Hi Bryan,
I would first suggest you upgrade to NI-DAQmx 8.9 and see if this fixes the issue. 8.9 is a more stable build than 8.8 and should provide you with the option to save your scales, devices,and tasks.
05-01-2009 05:43 PM
I have my developer dvd's that I need copied onto a thumbdrive so I can upgrade or install when needed. Is there a way of integrating DAQmx 8.9 into the developer dvd directory structure replacing the 8.8 version? I would rather replace the old version rather than having both.
 Will_S.
			Will_S.
			05-04-2009 02:58 PM
05-04-2009 05:04 PM
The dvd's are from the latest devloper release, Feb 09 (8.6.1).
 Will_S.
			Will_S.
			05-06-2009 05:45 PM
 Broken_Arrow
			Broken_Arrow
			05-11-2009 10:49 AM
 Broken_Arrow
			Broken_Arrow
			05-11-2009 01:03 PM
I upgraded to DAQmx 8.9, and MAX still does not export channels or scales. I did not have this problem with LV 8.5.1, just after upgrading to 8.6.1.
05-11-2009 01:34 PM
The machine I was having problems with was upgraded from 8.2 to 8.6.1. I have not had a chance to upgrade max yet, so I have no idea if it works yet or not.
 Dennis_Knutson
			Dennis_Knutson
			05-11-2009 02:10 PM
