DAQmx 1D waveform NChan NSamp vs Duration?
What is the difference between DAQmx 1D waveform NChan NSamp vs DAQmx 1D waveform NChan Duration? The documentation does not seem to document the duration version.
(1,695 Views)
Yeah, that's a limitation in the documentation.  My understanding (I have not used this exact function) is that it will read the number of samples in the given duration.  I guess it makes things a little cleaner in that you don't have to do the math to figure out the number of samples in a given time (as most of us do in order to have a set loop rate).
(1,668 Views)
