DAQMx - two counters, one inverse of the other
I've not tested so far if really a counter is used to do the inversion. I will try to use the 2nd counter on the 6210 to perform another task. Regarding the toggling of the inversion: For this first the terminals need to be disconnected and then reconnected. I did not find a property node for routes. There is one minor problem with my code: It still leaves the routed terminal sometimes in the high state after termination. Suggestions how to prevent this are welcome 🙂
Uppdate: My statement above is wrong, I just terminated the VI with the stop sign in the menu and not the stop button. With the stop button, it works as expected.
Christian
Message 11 of 13
(646 Views)
Seemingly, the route requires a counter. When trying to route with the other counter being used for a different task, I getan error:
Possible reason(s):
Specified inversion cannot be satisfied, because it requires resources that are currently in use by another route.
Source Device: Dev2
Source Terminal: PFI4
Destination Device: Dev2
Destination Terminal: PFI5
Required Resources in Use by
Task Name: _unnamedTask<1AD>
Source Device: Dev2
Source Terminal: 80MHzTimebase
Destination Terminal: Ctr1Source
Message 12 of 13
(634 Views)
So it is really the inversion that needs a resource (counter). When I switch of inversion (just route the output), no error message and behaviour as expected. Is that documented somewhere?
NI hardware is cool
NI software is okay
NI documentation is a mess
Message 13 of 13
(628 Views)
