DAQMX + visual basic
I have created a Task that output voltage signal +5 volt to - 5volt . I wish to use this task either using Visual basic or using VB.net. Can any body give me the simplest way to do this.
Any tutorail or information on this topis would be a great help.
Regards
Nadeem
(2,793 Views)
For question on using VB or .net, you should post to to either the VB6 board or the .NET board. There is even a dedicated Multifunction DAQ board. There are also example programs that get installed with DAQmx.
(2,778 Views)
