DAQ
Hi friends,
                i'm doing a project by converting TTL signal to NIM signal. now, i need to interface the output of the project with PC.the data acquisition is just to show the wave form in the waveform graph. the voltage for NIM for logic 1 is -1V and logic  0 is 0.2 V. kindly wanna ask, what is the next step i going to do for the interfacing part.
my question
1. what i gonna use for the DAQ? digital input or analog input? if any of them, what is sub DAQ i going to used?
2.im using labview 6i to do the interfacing and daq card PCI-6024E 68 pins.but i used the converter to change the pin from 68 to 50 pin and the  connector block  for DAQ.
looking forward to hear from you guys. thanks a lot
I'm newbie of Labview and maybe i asking some kind of stupid questions. anyway, i'm desperate for help. thanks.
best regard
(3,716 Views)
Hi Syegg,
The PCI-6024E is TTL compatible, which would allow you to read in TTL signals via a digital input.  To read a NIM signal, you would need to use an analog input.
I assume because you are using LabVIEW 6 that you are programming with the Traditional NI-DAQ driver version 7.1 or earlier (or 7.2 if you have LabVIEW 6.1).  If you don't have it installed already, you can do so here:
Traditional NI-DAQ 7.1
http://joule.ni.com/nidu/cds/view/p/id/106/lang/en
To find example programs for analog input, look in this directory on your machine:
C:\Program Files\National Instruments\LabVIEW 6.0\examples\daq\anlogin\
If you let me know a bit more about your application, I can direct you to a more specific example.  What sampling frequency do you require and how many channels will you be acquiring at a time?
John Bongaarts
(3,691 Views)
hi, thanks for reply.
first of all, i need to read 2 signals in 2 different channels.
im using the 50 pin E serries connector, and the channel for TTL is pin 25 , DIO 0, and for NIM is analog channel pin 3.
i need to put the input singal into 2 diefferent waveform graph and another 1 is comparison of 2 signals in a waveform graph which i bundle waveform graph 1 and waveform 2.
thanks for help man.
regards,
chang.
(3,674 Views)
Hi Chang,
For your application, I would recommend starting with the example called "Continuous CDI with AI (E).vi" found in:
C:\Program Files\National Instruments\LabVIEW 8.5\examples\daq\digital\E-series.llb
Try playing around with it and see what you can come up with.  Let me know if you run into any bumps as you customize it for your application.
John Bongaarts
(3,642 Views)
