DAQ
Hi, I'm having an issue viewing the DAQ assistant once my device is connected. Has anybody experienced a similar issue and has a solution? Thanks.
Message 1 of 18
(5,388 Views)
Hi stephen,
welcome to the forum!
Maybe you should tell use the type of the "issue"?
It's like asking a mechanic for "My car has an issue. Have you heard from other customers the same?"
Message 2 of 18
(5,384 Views)
Once I have connected a thermocouple via the DAQ, the DAQ assistant isn't viewing via the inputs.
Message 3 of 18
(5,374 Views)
Hi stephen,
Where does the DAQAssistent "view" anything?
Which inputs?
Please show your VI or atleast a snippet…
"Lesson learned": when having a problem with a VI you should attach that VI. This is much preferred over attaching just pictures of the block diagram. LabVIEW also provides "snippets", please look up that word in the LabVIEW help!
Message 4 of 18
(5,368 Views)
And which DAQ board are you using?
Thermocouples are typically pretty low in signal and fairly constant.  You might just be trying to read at too high of a range.  But this is pure guessing without having a VI to look at.
Message 5 of 18
(5,358 Views)
As you can see from the attached screenshot, Once the Device is connected via the DAQ I am unable to view the DAQAssistant
Message 6 of 18
(5,347 Views)
Well that's weird!  We all thought you were talking about viewing data but you meant that the VI itself has disappeared.  Smiley Frustrated  The other VI missing is the Simulate Arbitrary Signal ExpressVI.
You say this happens when you connect your hardware?  Tell us exactly what hardware and how you have it connected.  What DAQ card (or USB module) and what kind of "device" are you connecting to it.  Are you saying this happens only when you connect a sensor to the physical DAQ card inputs???
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 7 of 18
(5,338 Views)
Try to search on Instrument I/O ... Or simply use the search tool !
Message 8 of 18
(5,334 Views)
Im just using an NI Thermocouple input connected through a high speed USB carrier to the laptop USB port (converting the DAQ to USB). Once connected I simply can't see the DAQ Assistant, regardless of a search.
Message 9 of 18
(5,328 Views)
Can you see your hardware on MAX ?
Message 10 of 18
(5,326 Views)
