DAQ using a minilab
HI, I am trying to carry out an acquisition using a minilab. I have made the software interface for the setup and would like to know the electrical part of hoe to make the actual connections.
I will explain the experiment in detail. I have a device on which i am putting weights. The device is connected to a multimeter. So as i put a weight the multimeter shows a given volatge reading. Now before using DAQ we were using this voltage reading for different weights and doing the calculations manually. Now i have written the interface for it and now want to test it using the labview. I have a USB minilab. The minilab has different channels such as 0 and 1 abd grounds. How do i connect the multimeter to the minilab. I will connect the minilab to the comput
er.
Also what should i change in my labview code. Should i put scanrate and channel etc.
(2,688 Views)
Hi gauravm,
I am a little confused as to what part of your application is created in LabVIEW. If you mean the software interface you created is in LabVIEW, then you can just use it as a subVI inside of your LabVIEW test application. If the interface was created in a different environment, then you can use the Call Library Node along with your interface exported as a DLL.
Hope this helps!
Jeremy L.
Jeremy L.
(2,688 Views)
