DAQ sub folder missing in Labview 7.1
I have tried to install Labview 7.1 on Windows 2000, but the installation appears to miss the DAQ toolbox subfolder. I recognize that this is a problem which has been adressed in the knowledge web, i.e. http://digital.ni.com/public.nsf/websearch/5B198936A1B8D6F286256BDF0078C5F5?OpenDocument
However, I am shocked that it has still not been corrected in the latest release. By going in to the custom install, I am able to install support for DAQ support for Labview 7.0. However, the menu file fopr this component, as well as the lib files are placed in a folder, Labview 7.0, while the rest of the installation is in Labview 7.1. This cannot be easily solved by dragging and dropping the appropriate folders.
Is there a proper solution to this boondoggle?
(2,623 Views)
Hi
As descriped in the KB you are refering to, this was an issue with the old driver 6.9.0 and LV 6.1. This was fixed a long time ago, so you must be experiencing another problem.
What driver version are you trying to install?
Todays driver version is 7.4.
Regards
Anders M
NI Denmark
(2,608 Views)
