DAQ problems with VI server
I'm using dynamic VI calls with VI server, since I have to distribute my application as well on computers which do not have Ni-DAQ installed. Now I have a severe Problem. If i dynamically call the DAQ Occurrence Config.vi, I get the error '-10089 at AI Control'. If I call this VI directly, everything works fine (with the same parameters, of course). It seems that there is a problem with buffer allocation (I'm using Windows ME).
Does anybody know an answer for the problem? Thanks
Markus
(3,007 Views)
I would recommend reporting this to NI's technical support. You know that the parameters that you are passing the function are correct, so I would guess that the interaction between VI server and NI-DAQ is causing the problem. Be sure to let them know the versions of the software that you are using.
Erin
(3,007 Views)
