DAQ mx Project/MAX task Problem
Hello Sandra
Thank you verry much for your investigation and for your tips. I will include the hardware configuration in the installer as you said. I know how this is done. If it does not work, I will ask of course.
In the development environment, the project task works without any problem. Only in the executable it refuses to work, no matter on what computer.
Greetings
shb
Message 11 of 12
(787 Views)
I have a DAQmx project all built up and running along with creating an executable that runs on the same machine that I used for developing the project. I also created an installer for the same project on the original machine. The question that I have is that will this newly installed application run as expected  when this application is installed on another computer that does not have the LabVIEW engine or MAX installed on it?  Will that installer also include the necessary run time engine and the tasks that were created on the original machine?  Or do I have other things to include in the installer to make this run on the other machine?
Message 12 of 12
(622 Views)
