DAQ assistant trouble
I have my DAQ assitant reading two channels simultaneously (both are voltage reading in the order of milivolts). When I plot the data from the assistant, both signal are clearly shown and when each channel is triggered I can see teh voltage go up. I set up a trigger so it starts a loop.
This trigger is connected directly to the DAQ assistant data but it only works for one of the channels. What going on?? Please help
(2,683 Views)
Hey kruhun,
Are you using a hardware trigger or a software trigger? Is the trigger starting the acquisition? It might be best if you just posted a simplified version of your VI that shows the issue.
Chris Delvizis
(2,651 Views)
