DAQ assistant to array
I'm trying to write voltage from the daq assistant into an array and then store this in a file.  All I get in the file is the initialized array.  I just want the voltage once per second to be read into the array and then after 20 seconds have an array to store in a file.  I've tried to change the sampling rate and add in a wait until vi, but this doesn't work either.  Can anyone tell me what I'm doing wrong.  Thanks.
(5,530 Views)
Hi slarkin712,
change the datatype of your array to "dbl", then you get the real values. See attached your modified vi.
Mike
(5,520 Views)
