DAQ assistant error
Hi.
I've just installed LabView Community edition 2023 Q3 on Windows 10 PC
but, when I try to use DAQ assistant, I receive this error:
Any idea?
Thanks in advance
(2,404 Views)
Hi mforbiz,
use DAQmx functions as explained here or in all those DAQmx example VIs…
(This is NI's way to tell you not to use ExpressVIs too much… 🙂 )
(2,377 Views)
Hi GerdW.
Thanks for your reply.
I've followed your suggestions but without success.
I state that:
1) I've used LabView for many times and in many differenet versions across about 20 years and never I've found this issue.
2) I'm using , for the first time, community edition.
Any other idea?
(2,331 Views)
Hi mforbiz,
  1. Your specific issue was reported several times for the most recent LabVIEW versions, search the LabVIEW board…
  2. I don't use the CommunityEdition so far, so I cannot comment on its behaviour. But I guess your problem is not related to the LabVIEW edition…
(2,322 Views)
Accepted by topic author mforbiz
Problem solved after 2021 SP1 installation.
(2,276 Views)
I'm having the same error can you send me the link for the download please.
(2,056 Views)
