DAQ assistant encoder
Hardware: DAQcard PCI-6250.
I'm trying to look at a signal from a vibration sensor and relate it to the angle of a rotating shaft measured with an optical encoder.
I've used two DAQ assistants inside a while loop.  Both of them work OK independently, but the encoder part only takes one measurement at the start of each loop (vi attached).
Does anybody know how I can synchronise its measurements to the vibration sensor?
All suggestions gratefully accepted...     Jack
(2,990 Views)
Hi Jack
Your program is reading continuously from the vibration sensor at 1KHz while you are reading one sample on demand (software-timed sample) from the optical encoder. Therefore, they are out of sync.
You should modify the timing settings to match each over. Double-click the DAQ Assistant and configure the task parameters.  What kind of sampling frequency is appropriate for the vibration sensor and the optical encoder in your application?
KostasB
NI UK
(2,967 Views)
