DAQ assistant different positions
Hello
In my VI i want to get some Signal of a PCI 6221 37 DAQ Card. I read in 2 signal which i need in different states of my application. therefore i tried to get the signals with 2 daq assistans which read date from the same card. but if i run the vi i get an error.
How can a get my data from the same card from different positions in my block-diagramm?
thanks
Simon
Using Labview 7.1
(2,554 Views)
You should just have both channels in a single DAQ Assistant. You can then use the Split Signals function.
(2,544 Views)
