DAQ assistant analog input voltage
Does anybody know why theres's error when using two DAQ assistant(In a while loop at the same time) for reading analog input voltage?
There's not a problem if using one DAQ assistant for reading single analog input voltage.
(2,735 Views)
Accepted by topic author JohnS11
If you are getting an error, wouldn't it help if you told us what it was so we can be able to explain it?
I'm guessing you have error -50103, and if you search the forums for "50103"  (leave out the negative sign), it will give you the answer since this question has only been asked thousands of times before.
(2,728 Views)
