DAQ and Labview on different partitions
I installed DAQmx (8.9) on a  C partition and Labview (8.6) on a D partiton  but LV does not see DAQmx ?
Is it the reason ?
I tried to edit the path the palette (I would have like to just replace the D by a C), in fact LV looks for in C:\Na......\menu.mnu.
I also tried to add a palette, but then a lot of VI are missing.
I also wanted to modify the labview.ini, but I was not able to recognize the path to the  palette tool.
To I tried to reinstall LV from the DVD and when it asks my for the driver, I tried my own installation, but the installer asks me
insert media for the driver. I do not have the media for 8.9 (the one on the media is 8.7.9 if I am correct), so I tried to
give it the path of the dowloaded file(NIDAQ890f1) as well as the path to the directory where I unzipped the dowloaded files,
but any of thoses paths are accepatble for the LV Installer.
Is it not possible to have a separated installation of DAQ and LV ?
Thank
(2,574 Views)
Hi pdupre,
i never tried to install it on different pations, but in which order did you install it? You first have to install LabVIEW and then the Driver.
Hope it helps.
Mike
(2,557 Views)
