Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
09-16-2011 05:11 PM
Hi All,
I am collecting data using two SCXI chasses with 1120 amplifier modules and SCXI 1112 thermocouple modules.
I am monitoring 12 input voltages and 4 thermocouple inputs.
I have set the samp,e rate to 2500S/s, and I am letting the software figure out how many samples to take each measurement.
Most of the time, the system runs fine, at about a 16ms loop time. However, every few seconds, the system will hang up for ~500ms between readings. Any thoughts as to what might cause these hangups?
I wonder if I am overflowing the read buffer. Could that result in this type of behavior? I think there is a way to monitor the read buffer, but I forget how to do it. Can anyone tell me how to do that?
Many thanks.
Solved! Go to Solution.
09-17-2011 12:47 AM
You can monitor the read buffer by using the DAQmx Read Property Node and choosing Status->Available Samples per Channel.
09-19-2011 12:26 PM
Hi Adnan,
Thanks for the help! I am now monitoring available samples.
I have realized that the problem is not in that buffer. I only get the problem when I have the "Logging" function turned on so the program is writing data to a text file. I will look into that issue by monitoring the write buffer to see if that is what is overflowing.
09-20-2011 12:56 PM
I am not sure about your architecture but hope you are using a producer/consumer design pattern. You can find this by going to File -> New.. and browse down to Producer Consumer Design Pattern (Data)
09-20-2011 01:03 PM
Aha! Someone else took a picture of the Producer/Consumer Design Pattern, but I did not realize it was a standard template. This is EXTREMELY helpful. THANKS!
