DAQ Solutions not available on NI8176
DAQ Solutions not available on LAbview 6.1,DAQ Solutions button not highlighted cant be selected on opening Window. Hardware listed below.
- Installed on Embedded Controller NI8176/W2K.
- in PXI-1011 Chasis, NI 4472 in PXI slot, using a 6052E DAQ Card, SCXI Modules - 1540, 1520, 1102
(2,634 Views)
Hello;
If you had another version of NI-DAQ installed before upgrading Labview to version 6.1, the best way to go about that is to uninstall NI-DAQ completely, and install the 6.9.2 version of the driver that goes with the Labview CD. To do that, just run the Labview installer and select the NI-DAQ driver from the list (choose custom install).
Hope this helps.
Filipe A.
(2,634 Views)
