DAQ Related Error
I am confronted with a problem regarding data acquisition. I am acquiring data (refer to the attached image) continuously from four analog channels. Rate of acquisition is decided by HZ which varies depending on the requirement. Now while test is under progress the available no. of samples is initialized to zero & the test ends abruptly. I am unable to find a solution to this problem. Kindly revert to me asap at vallabh@ducom.com. I am using NI-6221 data acquisition card.
Regards
Vallabh Mahajan
09880020907
(2,895 Views)
You are acquiring from 5 channels, actually. You don't show the code for the read, don't mention the range of your sample rate, and don't mention the actual error code that you get.
p.s. Posting your email address will only get you spam.
(2,881 Views)
