DAQ Problem
 Hallo everyone
I have a problem, I try to provide a task in order to mesure the Voltage with the help of the DAQ-Card.
normally under the list " Supported one physical channels" should indicate the available channel of all existing DAQ-Card.
however it is not the case with me , it is written : " No Support devices found ".
Although i installed the drivers 2 times and  the Test Panel of DMM ( PXI-4065) and of DC power supply (PXI-4110)are working.
Would u plz tell me what should i do , and where is the problem
P.S : it is my second week  that i am working with LV
(3,825 Views)
PXI-4065 and PXI-4110 are not DAQ card
use "help>>Find examples" and select your hardware (see PNG)
Message Edité par A. Dek... le 02-12-2008 09:38 AM
(3,821 Views)
hi Dek
i do it but the file was empty 😞   ( see Pic)
and the DAQ - assisstant is also empty
Toni
(3,810 Views)
Hi Toni,
have you this palette ?
if no, perhaps you don't have installed the correct library
(3,805 Views)
hi
you are right i don't have it ( see Pic3) , how should i  install the correct library ,
from the CD (NI-DCPower)  which i recieved whith the package
be patience on me  , like i toled u , i am a beginner and no one can help me in the office
thx
(3,797 Views)
hi
I think it is in the Driver CD received with labview
you can also use MAX (measurement and automation explorer) to see softwares, drivers and hardwares installed in your PC
(3,792 Views)
