DAQ - Measurement - Extraction of DataSet - PCA Analysis
How do you get the data
as file (please provide a sample)?
in your application (if you want to use the detector during measurement) (format and samplerate)?
do you get more than one channel?
Greetings from Germany
Henrik
LV since v3.1
Message 21 of 25
(881 Views)
here is a version to read files and index the data (no adding of more channels for detection to reduce noise )
Henrik
LV since v3.1
Message 22 of 25
(867 Views)
 I get the data using an instrument basically multimeter (I/V). I read time dependent resistance values. I have 3 channels and each channel does the same measurements using different current values.
I attached the R values obtained by only one channel. the first columns represents the time and the second column represents the R values. Each R values is measured and recorded with its time.
tiem(s) R (ohm)
0.1       3550
0.13     3570
0.2       3800
0.26     3910
yes, I have 3 different channels, and ı save all in one file. The time for 3 channels are the same
Message 23 of 25
(862 Views)
This is What I generally receive from the measurements. Time dependent values from 3 different channels.
I cannot process this data with the last version neither. As you open the file, you will see that the array displays the data.
Message 24 of 25
(854 Views)
Henrik, Cool!
It works and reads my data. I was making a mistake while compiling it. Now there is an offset from the actual data and peaks and valleys. I will play with it.
Cheers
M
Message 25 of 25
(830 Views)
