DAQ Interference among channels
Hi there,
I am suffering from an interference problem now while I am doing some DAQ work.
I am using LabVIEW to control the DAQ system to grab voltage signal from several thermocouples. The results make sense for me but I found there seems to be some interence issues among all the channels: from the plot attached it is clear to find some simultaneous fluctuation on all the curves (see the portions of curves in the numbered boxes 1, 2, 3 and 4).
My block diagram is also attached here (which seems to be messy and vulgar-designed for you guys since I am a newbie on LabVIEW)
I am wondering if this is an interference issue with hardware or a problem on my programming, and please lemme know how to handle this problem to reduce (or even cancel the interferences).
Thanks.
(3,159 Views)
Accepted by topic author abright
Search the Forum for posts on "ghosting"
Lynn
(3,142 Views)
Thanks!
(3,131 Views)
