DAQ Input Signal into Array
I have an input (voltage) signal comming into my DAQ assistant (6008). This information displays well into a chart, but I also want to covert the same data into array format so that I can do further calculations. So, basically I would like to put a DAQ signal into an array. I'm having a lot of trouble doing so, please help,
thank you
Nick
(2,821 Views)
Hello Nick,
I can use the function "From DDT" in the Function palette Express -> Signal Manipulation.
When you place it on the block diagram, a windows opens and you can configure: 1D Array of Scalar - Automatic.
Best regard
Nick_CH
(2,818 Views)
